Dyan
How do i put the generated graph to a journal
GB = Graph Builder(
	Size( 621, 472 ),
	Variables(
			X(colX[i]),
			Y(colY[i])
	Elements(
			Position( 1, 1 ),
			Points( X, Y, Legend( 67 ) ),
			Smoother( X, Y, Legend( 68 ) )
		Dispatch(
			"Graph",
			ScaleBox,
			{Label Row( {Show Major Grid( 1 ), Show Minor Grid( 1 )} )}
graph = GB << Graph;
Hi all may i ask how can i edit this script such that it will show up in my current journal? As of now what all this does is open a new window with the full interactive graphbuilder and leaves the journal blank.
This is a part of a bigger script where there are other generated graph not made using graphbuilder and are able to be placed in the journal.
this is JMP 16
Re: How do i put the generated graph to a journal
Using <<Journal should work
//This message applies to all display box objects
obj = dt << Graph Builder(
	Variables(X(:Sex), Y(:Height), Group X(:Age)),
	Elements(Box Plot(X, Y))
rep = obj << report;
rep << journal;
rep << journal;
