nthai
How do i plot overlay chart similar to Analyze >> Quality and Process >> Control Chart >> EWMA Control Chart
Hi all,
I think the title pretty much speaks for itself. There's one property "Overlay Charts" when i choose, it will overlay the Y and Y EWMA data into 1 chart. I think it's suitable for my need but dont know how to re-generate.
ih
Super User (Alumni) ih
Re: How do i plot overlay chart similar to Analyze >> Quality and Process >> Control Chart >> EWMA Control Chart
Here is how you can build that chart interactively:
(view in My Videos)
You will need to create your own EWMA column.  The function, Simple Exponential Smoothing() should be able to give you the EWMA you need.  You will also have to create an X column based upon the row number.  Below is a simple example.
Graph Builder(
	Size( 723, 578 ),
	Variables(
		X( Transform Column( "Row", Formula( Row() ) ) ),
		Y(
			Transform Column(
				"EWMA",
				Formula( Col Simple Exponential Smoothing( :height, 0.1 ) )
		Overlay( :sex )
	Elements( Points( X, Y, Legend( 6 ) ), Line( X, Y, Legend( 8 ) ) )
ih
(view in My Videos)
nthai
Thank you ih, by demonstrate step by step it is much easier for me to follow up :)
