How do i get the best 4 choices ?
Hi, I'm new here.
I used the JMP to draw some choice sets for a choice modelling project. I have 32 choice sets however I need to choose the best 4 out of the 32 choice sets. I would like to know how to do that using the software.
I generated these 32 choices from the JMP software using (DOE- consumer studies--Choice design) options from which I want to choose the best 4. I keyed in 3 attributes with two attributes having 4 levels and 1 attribute having 2 levels.
Is there any command to use to generate the best four choice sets?
ian_jmp
Level X
Re: How do i get the best 4 choices ?
Perhaps I have misunderstood. But if you go through the design generation process:
then all of the choice sets are equally important in gathering the data required to fit the specified model. So what, exactly, do you mean by 'the best 4 out of the 32 choice sets', please?
