CAPEGA
How do I use Kerberos authentication HTTP request
Does anyone knows if Kerberos autehtication can be used with the HTTP request method from jmp? I have a API I would like to connect using this authentication method.  What are the different authentication methods that can be used? Is there any cURL object in JMP (https://curl.haxx.se/)? It would be nice if you could provide an example, if available. Thank you in advance.
Here is a sample of a request
request_headers = AssociativeArray();
request_headers["Authorization"] = "";//Kerberos example
request = New HTTP Request(
	URL( url ), // the restAPI endpoint
	Method( "Get" ),
	Headers(request_headers),
	Query String( // define key pairs
		[["count" => limit]] // JSL associative array
12 REPLIES 12
sheila_loring
Staff (Retired)
Re: How do I use Kerberos authentication HTTP request
@Chris_Rodrigues, please accept my apologies. I will make sure this information is added to the JMP 16.1 documentation.
In JMP 17, there are now:
UersK
Thanks!
