EMJohnson-Kueny
How do I share a custom Categorical Color Theme?
Hello all,
One of my co-workers is red/green color blind and has come up with a custom set of colors for the Categorical Color Theme that he can differentiate clearly. I've tweaked it a little to reduce errors in graphing and to dial back the really bright colors just a smidge. Is there a way to easily share this set of colors with others in our group? Right now it's a Power Point slide with RGB values to manually enter which is time consuming.
Thank you,
E.M.J.K.
Re: How do I share a custom Categorical Color Theme?
The JMP Help webpage for Create Color Themes discusses how to save and add to another copy of JMP the custom color themes.  It can be found here
I tried to change a deuteranopia color theme.  It saved a custom theme, but it appeared to change as a Chromatic theme.  One may not be able to change an deuteranopic theme.  It does not say that in the help screens but then I also do not see any documentation on deuteranopic themes either.
You may want to contact JMP Support if you don't get a clarifying response from the Community.
EMJohnson-Kueny
Thank you very much! I was able to create the log with the preferences. We'll have to wait to see about adding it due to admin access issues, but I can't get too mad about good security.
ron_horne
Hi @txnelson ,
any idea how to do this on JMP 18? i am trying to set the theme to accommodate deuteranopia.
once i select it save the theme and save the settings nothing really happens and i can't find the saved theme again.
thank you
