fionaweston
How do I script to change the name of my columns, presently dates, to just the day?
I  want to change just the numeric continuous columns in my sheet which are presently full dates and are in order from 1st to 31st to just the day
ex 03/01/2020 to 1
03/02/2020 to 2
I would also like to add a column to my sheet with the Abbv Name of the Month.
Thanks in advance
Re: How do I script to change the name of my columns, presently dates, to just the day?
Here is how I would solve your request
dt = Current Data Table();
theMonth=.;
For( i = 1, i <= N Cols( dt ), i++,
	If( Substr( Column( dt, i ) << get name, 1, 2 ) == "N(",
		If( isMissing(theMonth) == 1,
			theMonth = Month( Informat( Word( 2, Column( dt, i ) << get name, "()" ), "m/d/y" ) );
		Column( dt, i ) << set name(
			Char( Day( Informat( Word( 2, Column( dt, i ) << get name, "()" ), "m/d/y" ) ) )
monthList = {"Jan","Feb","Mar","Apr","May","Jun",
	"Jul","Aug","Sep","Oct","Nov","Dec"
dt << New Column( monthList[theMonth]);
Georg
You could do it like this:
dt = New Table( "Dates",
	New Column( "date", "Numeric", "Continuous", Format( "Date Abbrev", 20 ), set values( Date DMY( Index( 1, 31 ), 3, 2020 ) ) )
Wait( 3 );
dt << New Column( "Day", Formula( Day( :date ) ) );
dt:date << hide();
dt << New Column( "Month",
	Formula(
		Match( Month( :date ),
			1, "Jan",
			2, "Feb",
			3, "Mar",
			4, "Apr",
			5, "May",
			6, "Jun",
			7, "Jul",
			8, "Aug",
			9, "Sep",
			10, "Oct",
			11, "Nov",
			12, "Dec"
Georg
theMonth=.;
fionaweston
Thanks Jim, this is great.
