CMG
CMG
How do I save a subset of tables only?
Let's say we have a table with 3 columns (example below). I create a subset of tables by the "city code" column that will include all 3 columns.
City codeRegistration NumberRegistration Date
032032053764820201026
160160008408220201020
281282116256620201020
325325048850020201024
420420061884320201101
511511068017420201027
720720005473720200825
I would like to save only the subset files as text files as follows: city code value.txt
I found the following jsl script on the forum which was very helpful in saving the files as text files. The issue is that the files are saved as city code = value.txt
The main data table is also saved a text file, which I don't want.
//Save as txt file
openDTs = {};
For( i = 1, i <= N Table(), i++,
     Insert Into( openDTs, Data Table( i ) )
For( i = 1, i <= N Items( openDTs ), i++,
     one_name = openDTS[i] << get name;
     file_path = one_name || ".txt";
     openDTS[i] << Save(file_path);
I am new to both JMP and scripting, so any ideas are very much appreciated.
Re: How do I save a subset of tables only?
Below is a script that will create the Example data table you provided.  It will then create the subsets, and save each subset as a .txt file.
All that needs to be done to run this example, is to change the line of code
saveFolder = "C:\xxxxxxxxxxxxx\";
to what the actual path to the folder to save the files into, and then run the code
// Create the example data table
New Table( "Example",
	Add Rows( 7 ),
	New Column( "City code", Numeric, "Continuous", Format( "Best", 12 ), Set Selected, Set Values( [32, 160, 281, 325, 420, 511, 720] ) ),
	New Column( "Registration Number",
		Numeric,
		"Continuous",
		Set Values( [320537648, 1600084082, 2821162566, 3250488500, 4200618843, 5110680174, 7200054737] )
	New Column( "Registration Date",
		Numeric,
		"Continuous",
		Set Values( [20201026, 20201020, 20201020, 20201024, 20201101, 20201027, 20200825] )
// Here is the real code.....just change the saveFolder =    to the actual folder you want to
// save the files to
dt = Current Data Table();
// Create the subsets
dtSub = dt << Subset( By( :City code ),
	All rows, Selected columns only( 0 ),
	columns( :Registration Number, :Registration Date ) );
For( i = 1, i <= N Items( dtSub ), i++,
	// Given the structure of the data tables created with a Subset using a By() clause
	//      City Code = 32
	// the Word() function retuns the "32" and it is added as the name of the file to save
	dtSub[i] << Save( saveFolder || Word( -1, dtSub[i] << get name, "=" ) || ".txt" )
CMG
CMG
@txnelson Thank you so much! Worked like a charm.
	Add Rows( 7 ),
		Numeric,
		"Continuous",
		Numeric,
		"Continuous",
	//      City Code = 32
CMG
CMG
