WernerL
How do I replace missing values in a column using Last Observation Carried Forward (LOCF), or K Nearest Neighbors (without JMP Pro)?
Hi JMP Community, I have a table with in the first column all days of the year and in the second column a significant number of missing values.
I am looking for a solution to replace in the second column (or create a new 3rd column) the missing values by Last Observation Carried Forward (LOCF)? I cannot seem to find this functionality in JMP?
Alternative, I would like to replace the missing values by K Nearest Neighbors, which I noticed is available for JMP Pro users. Is there a work around for regular JMP users?
Thank you for your help!
Re: How do I replace missing values in a column using Last Observation Carried Forward (LOCF), or K Nearest Neighbors (without JMP Pro)?
Attached is a data table with a new column that contains a simple formula that creates your requested Carried Forward value.carriedforward.PNG
jules
Hi @Werner,
I actually prefer a column formula solution like @txnelson suggested because it retains your original data, but in some cases you might find you want to simply fill-in those missing values with the previous value (I do this often when date ranges aren't spanned). If you have JMP 14 or newer, you can use the Replace Missing Values with Previous Values data table right-click function. Select the entire column, then right-click a cell > Fill > Replace Missing with Previous Value.
I hope this helps!
@jules
jules
Hi @Werner,
I hope this helps!
@jules
Well, once again I have been shown something new in JMP..... @jules  thanks
WernerL
@jules , I agree with you that the solution proposed by @txnelson has the big benefit of maintaining the starting base, hence preferred. Many thanks both for your swift responses! WernerL
