Andyon98
How do I make a list of strings containing the titles of opened data tables from a button using the open function?
Exactly as the title suggests, im trying to make a list of strings containing the titles of the files I am using from using the open(); function.
Re: How do I make a list of strings containing the titles of opened data tables from a button using the open function?
Depends on the application.
You could initialize list and then add new table names to it with Insert Into() when needed (use << get name to datatable reference if needed).
dt_name_list = {};
show(dt_name_list);
dt1 = Open("$SAMPLE_DATA/Big Class.jmp");
Insert Into(dt_name_list, dt1 << get name);
show(dt_name_list);
dt2 = Open("$SAMPLE_DATA/Cars.jmp");
show(dt_name_list);
Or you could get all open table names and then remove unnecessary ones from that list
dt_name_list = Get Data Table List() << get name;
dt_name_list = {};
show(dt_name_list);
show(dt_name_list);
show(dt_name_list);
Andyon98
This looks good! I can work with this, thank you!
