How do I get VIF to display in the parameter estimates column
I want to check the VIF scores for a nominal logistic regression. When I right clicked on the parameter estimate table -> column, VIF option is not displayed. Any suggestions on how to add-in VIF as column? I'm using the latest version of JMP pro on windows.
Re: How do I get VIF to display in the parameter estimates column
Based on previous discussion How to find VIFs in a Nominal Logistic Regression? Using JMP Pro 14 there doesn't seem to be direct way of getting it you might have to use some workarounds (if situation is still same in JMP16).
Victor_G
Hi @CumulativeTiger,
In addition to jthi answer, you can display VIF values by default on other platforms with this path : go to File -> Preference -> Platform -> "Fit Least Squares", "Response Fit" and other Fit platform (not available in Nominal Logistic), and enable "Show VIF".
Victor GUILLER
