chetuthomas
How do I enter 3 time points on a single cell in jmp
I had an experiment to take three time points, kind of looking for ways to enter these time points on the same row labeled 1
SDF1
Re: How do I enter 3 time points on a single cell in jmp
Hi @chetuthomas ,
  I do not recommend having more than one time stamp in a single cell in JMP. If each row represent some kind of measurement at three different time points, then you should probably use three different columns Time1, Time2, and Time3, or something. That way, you can keep each time stamp separate and analyze thing accordingly.
Hope this helps,
DS
chetuthomas
Sure, that works. I just figured it out. I was thinking there is another way out. Thank you
SDF1
Hi @chetuthomas ,
Hope this helps,
DS
chetuthomas
