Re: How do I create a new column that sum the delta between to dates which are in different column?
Created:
Mar 14, 2020 11:45 AM
| Last Modified: Mar 14, 2020 8:47 AM(3995 views)
| Posted in reply to message from ileshem 03-14-2020
Assuming the Start and End1 columns are true JMP date/time columns, all that has to be done is to use the formula :End1 - :Start and then set the format for the new column to one of the Duration formats
