Owen_Kim
How do I concatenate some rows to new one including character with JMP formula?
I want to concatenate some rows to new one as below.
Column X, Column Y
--> New Column : Column X_Column Y
Can I use JMP formula to merge like this?
One additional question is when I add new column based on some formula, can I take JMP script for the data table containing formula column?
Re: How do I concatenate some rows to new one including character with JMP formula?
You can simplily create a new character column, and use the following formula to concatenate you columns into the new column.
char(:columnX) || "_" || char(:columY)
You need to read the Using JMP documentation
     Help==>Books==>Using JMP
