anne_sa
How do I check that a column contains only integers?
I need to check that a column contains only integers before running the rest of my script but I don't know how to do that. Ideally I would like to be able to identify precisely the rows with decimal values.
Thanks in advance for your help!
Re: How do I check that a column contains only integers?
See the last line.
Names Default to Here( 1 );
// generate test case with a mix of 90% integers and 10% non-integers
data = J( 30, 1,
	If( Random Uniform() < 0.1,
		Random Normal(),
		Random Integer( -6, 6 )
// check results
Show( data );
// make a data table example
dt = New Table( "Test Cases",
	New Column( "Data", Numeric, Continuous,
		Values( data )
// now the solution
nonIntegersHere = dt << Get Rows Where( Modulo( :Data, 1 ) );
See the last line.
data = J( 30, 1,
		Random Normal(),
// check results
Show( data );
		Values( data )
// now the solution
anne_sa
What a beautiful solution!! Thanks @Mark_Bailey
