How do I change my column value to an odd number
I am using jmp 16 and my objective with jmp is to create wafer maps.
The issue I am having is I need to slice it into 13 columns and no matter what I do, the program never converts the column value to an odd number.
Please let me know if you have a solution to change the number of columns from an even number to an odd number.
Re: How do I change my column value to an odd number
Try changing your X and Y columns to modeling type, Ordinal  . Then there will be one row/collumn in your wafermap for each distinct value of X and Y
