timothy_forsyth
How do I calculate population standard deviation in JMP.
When I use the distribution platform in JMP 14 the calculated standard deviation is the sample standard deviation.  How do I calculate the population standard deviation in JMP and when is it appropriate to use the polpulation standard deviation?
Thanks,
Drink deep, or taste not the Pierian spring
Re: How do I calculate population standard deviation in JMP.
sd( p ) = Sqrt( ((n-1)*(sd( s )^2)/n )
