lala
Level IX
How can this Encode URI be restored correctly?
This is the request parameter for POST.
 jj="query=A%E8%82%A1&urp_sort_way=desc&urp_sort_index=%E8%82%A1%E7%A5%A8%E5%B8%82%E5%9C%BA%E7%B1%BB%E5%9E%8B&page="||char(k)||"&perpage=100&addheaderindexes=&condition=%5B%7B%22dateText%22%3A%22%22%2C%22ci%22%3Atrue%2C%22indexName%22%3A%22%E8%82%A1%E7%A5%A8%E5%B8%82%E5%9C%BA%E7%B1%BB%E5%9E%8B%22%2C%22indexProperties%22%3A%5B%22%E5%8C%85%E5%90%ABa%E8%82%A1%22%5D%2C%22source%22%3A%22text2sql%22%2C%22type%22%3A%22index%22%2C%22indexPropertiesMap%22%3A%7B%22%E5%8C%85%E5%90%AB%22%3A%22a%E8%82%A1%22%7D%2C%22reportType%22%3A%22null%22%2C%22score%22%3A0%2C%22ciChunk%22%3A%22a%E8%82%A1%22%2C%22createBy%22%3A%22preCache%22%2C%22node_type%22%3A%22index%22%2C%22chunkedResult%22%3A%22a%E8%82%A1%22%2C%22domain%22%3A%22abs_%E8%82%A1%E7%A5%A8%E9%A2%86%E5%9F%9F%22%2C%22uiText%22%3A%22%E8%82%A1%E7%A5%A8%E5%B8%82%E5%9C%BA%E7%B1%BB%E5%9E%8B%E5%8C%85%E5%90%ABa%E8%82%A1%22%2C%22valueType%22%3A%22_%E8%82%A1%E7%A5%A8%E5%B8%82%E5%9C%BA%E7%B1%BB%E5%9E%8B%22%2C%22sonSize%22%3A0%7D%5D&codelist=&indexnamelimit=&logid=9e773e4ff7f0b6cba03f4d9cf8c7d6e0&ret=json_all&sessionid=9e773e4ff7f0b6cba03f4d9cf8c7d6e0&source=Ths_iwencai_Xuangu&date_range%5B0%5D="||dd||"&iwc_token=0ac9e84917630285903635912&urp_use_sort=1&user_id=Ths_iwencai_Xuangu_26xzxlyxjiwlbmavfeagegjldipdrrp9&uuids%5B0%5D=24087&query_type=stock&comp_id=6836372&business_cat=soniu&uuid=24087";
no Encode URI("");
query=AZ&urp_sort_way=desc&urp_sort_index=ZZZZZZ&page="||char(k)||"&perpage=100&addheaderindexes=&condition=[{"dateText":"","ci":true,"indexName":"ZZZZZZ","indexProperties":["ZZaZ"],"source":"text2sql","type":"index","indexPropertiesMap":{"ZZ":"aZ"},"reportType":"null","score":0,"ciChunk":"aZ","createBy":"preCache","node_type":"index","chunkedResult":"aZ","domain":"abs_ZZZZ","uiText":"ZZZZZZZZaZ","valueType":"_ZZZZZZ","sonSize":0}]&codelist=&indexnamelimit=&logid=9e773e4ff7f0b6cba03f4d9cf8c7d6e0&ret=json_all&sessionid=9e773e4ff7f0b6cba03f4d9cf8c7d6e0&source=Ths_iwencai_Xuangu&date_range[0]="||dd||"&iwc_token=0ac9e84917630285903635912&urp_use_sort=1&user_id=Ths_iwencai_Xuangu_26xzxlyxjiwlbmavfeagegjldipdrrp9&uuids[0]=24087&query_type=stock&comp_id=6836372&business_cat=soniu&uuid=24087
I tried several methods but none of them got the correct result.
1
 jj="\[query=AZ&urp_sort_way=desc&urp_sort_index=ZZZZZZ&page="||char(k)||"&perpage=100&addheaderindexes=&condition=[{"dateText":"","ci":true,"indexName":"ZZZZZZ","indexProperties":["ZZaZ"],"source":"text2sql","type":"index","indexPropertiesMap":{"ZZ":"aZ"},"reportType":"null","score":0,"ciChunk":"aZ","createBy":"preCache","node_type":"index","chunkedResult":"aZ","domain":"abs_ZZZZ","uiText":"ZZZZZZZZaZ","valueType":"_ZZZZZZ","sonSize":0}]&codelist=&indexnamelimit=&logid=9e773e4ff7f0b6cba03f4d9cf8c7d6e0&ret=json_all&sessionid=9e773e4ff7f0b6cba03f4d9cf8c7d6e0&source=Ths_iwencai_Xuangu&date_range[0]="||dd||"&iwc_token=0ac9e84917630285903635912&urp_use_sort=1&user_id=Ths_iwencai_Xuangu_26xzxlyxjiwlbmavfeagegjldipdrrp9&uuids[0]=24087&query_type=stock&comp_id=6836372&business_cat=soniu&uuid=24087]\";
2
 jj="query=AZ&urp_sort_way=desc&urp_sort_index=ZZZZZZ&page=\!"||char(k)||\!"&perpage=100&addheaderindexes=&condition=[{\!"dateText\!":\!"\!",\!"ci\!":true,\!"indexName\!":\!"ZZZZZZ\!",\!"indexProperties\!":[\!"ZZaZ\!"],\!"source\!":\!"text2sql\!",\!"type\!":\!"index\!",\!"indexPropertiesMap\!":{\!"ZZ\!":\!"aZ\!"},\!"reportType\!":\!"null\!",\!"score\!":0,\!"ciChunk\!":\!"aZ\!",\!"createBy\!":\!"preCache\!",\!"node_type\!":\!"index\!",\!"chunkedResult\!":\!"aZ\!",\!"domain\!":\!"abs_ZZZZ\!",\!"uiText\!":\!"ZZZZZZZZaZ\!",\!"valueType\!":\!"_ZZZZZZ\!",\!"sonSize\!":0}]&codelist=&indexnamelimit=&logid=9e773e4ff7f0b6cba03f4d9cf8c7d6e0&ret=json_all&sessionid=9e773e4ff7f0b6cba03f4d9cf8c7d6e0&source=Ths_iwencai_Xuangu&date_range[0]=\!"||dd||\!"&iwc_token=0ac9e84917630285903635912&urp_use_sort=1&user_id=Ths_iwencai_Xuangu_26xzxlyxjiwlbmavfeagegjldipdrrp9&uuids[0]=24087&query_type=stock&comp_id=6836372&business_cat=soniu&uuid=24087";
Thanks Experts!
Re: How can this Encode URI be restored correctly?
Build the string and then use Decode URI()?
lala
Level IX
Thanks Experts!
I see
lala
Level IX
jj="query=AZ&urp_sort_way=desc&urp_sort_index=ZZZZZZ&page="||char(k)||"&perpage=100&addheaderindexes=&condition=[{\!"dateText\!":\!"\!",\!"ci\!":true,\!"indexName\!":\!"ZZZZZZ\!",\!"indexProperties\!":[\!"ZZaZ\!"],\!"source\!":\!"text2sql\!",\!"type\!":\!"index\!",\!"indexPropertiesMap\!":{\!"ZZ\!":\!"aZ\!"},\!"reportType\!":\!"null\!",\!"score\!":0,\!"ciChunk\!":\!"aZ\!",\!"createBy\!":\!"preCache\!",\!"node_type\!":\!"index\!",\!"chunkedResult\!":\!"aZ\!",\!"domain\!":\!"abs_ZZZZ\!",\!"uiText\!":\!"ZZZZZZZZaZ\!",\!"valueType\!":\!"_ZZZZZZ\!",\!"sonSize\!":0}]&codelist=&indexnamelimit=&logid=9e773e4ff7f0b6cba03f4d9cf8c7d6e0&ret=json_all&sessionid=9e773e4ff7f0b6cba03f4d9cf8c7d6e0&source=Ths_iwencai_Xuangu&date_range[0]="||dd||"&iwc_token=0ac9e84917630285903635912&urp_use_sort=1&user_id=Ths_iwencai_Xuangu_26xzxlyxjiwlbmavfeagegjldipdrrp9&uuids[0]=24087&query_type=stock&comp_id=6836372&business_cat=soniu&uuid=24087";
