pbouzi0
How can I fit a second order exponential decay to my data?
David_Burnham
Re: How can I fit a second order exponential decay to my data?
The short answer is you use the Nonlinear platform: Analyze>Modeling>Nonlinear
Nonlinear Regression with Custom Models
Nonlinear Regression with Built-In Models
-Dave
DaveLee
Here is what I use to fit a Stretched Exponential, make a plot to  look for anomolies and fit using the Non-Linear platform.
Fade=Current Data Table():
Fade << New Column( "Stretched Exponential",
    Numeric,
    Continuous,
    Formula( Parameter( {a = 1, b = -0.01, c = 0.2}, a * Exp( b * :Hours ^ c ) ) )
biv=Fade << Bivariate(
    Y( :Std Output1 ),
    X( :Hours ),
        Dispatch(
            "2",
            ScaleBox,
            {Min( 0.65 ), Max( 1.05 ), Inc( 0.05 ), Minor Ticks( 1 ),
            Label Row Nesting( 1 ), Label Row( Show Major Grid( 1 ) )}
        Dispatch(
            "Bivar Plot",
            FrameBox,
            {Frame Size( 375, 279 ), Row Legend(
                Exp No,
                Color( 1 ),
                Color Theme( "JMP Default" ),
                Marker( 0 ),
                Marker Theme( "" ),
                Continuous Scale( 0 ),
                Reverse Scale( 0 ),
                Excluded Rows( 0 )
biv<<Journal;
f=Fade<<Nonlinear(
    Y( :Name("Std Output1") ),
    X( :Name( "Stretched Exponential" ) ),
    Iteration Limit( 100000 ),
    Unthreaded( 1 ),
    Newton,
    Finish,
    By( :Device ID ),
    Custom Inverse Prediction( Response( 0.7 ),
    Term Value( Hours( . ) ) )
f_rep = f <<report;
rep=Report( f[1] )[Outline Box (6)][Table Box(1)] << Make Combined Data Table;
rep<<Current Data Table<<Set Name("Combined T70 Predictions");
rep=Current Data Table();
rep<<New Column("Exp No", character, formula(Substr(  :Device ID , 1, 10 )));
Hope this helps. Please let me know if you need anything further.
Dave
