Y-Y
Y-Y
How can I add unilateral bar in stacked bar chart
Is there a way to add a unilateral bar to a stacked bar chart in JMP?
Re: How can I add unilateral bar in stacked bar chart
Hi @Y-Y ,
Yes, you can achieve this in the Graph Builder - I'm using the 'Tablet Production' sample data (found under help > sample index) to give this example.
Go to Graph Builder and place your X and Y responses into the correct box (i.e. Dissolution v API Particle Size).
Click the bar chart tool to activate the bars
Add the character column that you are using to guide the 'stacking' of the variables (i.e. Screen Size).
Right click the 'Bar' box on the top and go to Bar Style > Stacked
Error bars don't appear for stacked bars as JMP can't tell where the error is meant to be calculated.
Thanks,
Ben
