Andyon98
How can I access the code from the graph builder?
I am looking to access the code from the graph builder. How can this be done?
Re: How can I access the code from the graph builder?
Click on the red triangle and select
     Save Script
The script it will provide will allow you to regenerate the Graph Builder output you generated interactively.
If you are looking for the actual source code for the Graph Builder Platform, JMP source code is proprietary and not available.
To what 'code' are you referring?
     Save Script
Andyon98
Thank you, I was looking for the regenerated Graph Builder output!
