CompositeCamel5
How are the default response limits for desirability functions determined in the Prediction Profiler of a fitted model?
Victor_G
Re: How are the default response limits for desirability functions determined in the Prediction Profiler of a fitted model?
Hi @CompositeCamel5,
The default response limits for desirability functions used by the Prediction Profiler can be found in the column property Response Limits, either configured by default when you specify the objectives for each of your responses when creating a DoE, or you can add manually this column property and specify your objective regarding the response.
If you forgot to specify the desirability and objectives of your responses through this column property, you can do it in the Prediction Profiler, and then click on red triangle of Prediction Profiler, then Optimization and Desirability>Save Desirabilities. This will create the column property Response Limits directly for the response desirability you have configured in the Prediction Profiler.
Hope this answer will help you,
Victor GUILLER
