hogi
Level XIII
Hierarchy of open Data Tables
How can I get a hierarchy of all open data tables:
- subsets
- stacked / split table
- summary table
something like the tree structure in the main menu - or in the window list?
7 REPLIES 7
hogi
Level XIII
Re: Hierarchy of open Data Tables
in my last approach, I use @jthi 's trick to parse the enhanced log :
talk to enhanced log
But maybe, there is a more clever approach, hacking the window list view?
Unfortunately:
... and the window list ist not listed in get Window List()
mmarchandFSLR
Or specify data tables in the Get Window List() function?
open_tables = Get Window List( Type( "Data Tables" ) ) << Get Window Title;
mmarchandFSLR
Or
open_tables = Get Data Table List();
hogi
Level XIII
I know both function, but I did not know that they can be used to get the hierarchy of open data tables.
From the returned lists, how can I find out which table is a subset or summary of another data table?
Facing the same issue showing windows in the forthcoming new Assistant.    Currently just looking at the names and parsing on " - ".
hogi
Level XIII
Unfortunately, from the window name, one cannot conclude if the tables are linked or separate.
I submitted the question to JMP support : TS-00278736
the suggestion : submit the idea to the wish list.
done: GetOpenTableDependencyGraph() and others
For reports it is a bit easier as you can use << Get Data Table (annoying part is getting the platform reference). Oversimplified examples
get_reference_table_window = Function({reportwindow}, {Default Local},
	table = Empty();
	tablelist = Get Data Table List() << get name;
	window_title = reportwindow << Get Window Title;
	table = Empty(); // one should definitely match...
	For Each({tablename}, tablelist,
		If(Starts With(window_title, tablename),
			table = Datatable(tablename);
			break;
	return(table);
get_reference_table_helpkey = Function({reportwindow}, {Default Local},
	table = Empty();
	// look for OutlineBoxes with helpKey xml attribute
	obs = reportwindow << XPath("//OutlineBox[@helpKey]"); // can run out of depth, could also loop over outlineboxes
	objs = obs << Get Scriptable Object;
	For Each({obj}, objs,
		If(Is Empty(obj),
			continue();
		sobj = obj << Get Scriptable Object;
		If(!Is Empty(sobj),
			table = sobj << Get Data Table;
	return(table);
For data tables it does get more messy and can only rely on name and source table script for non-linked tables. For linked tables you have some more involved strategies you can try.
