Sburel
Help with retrieving value from argument
I'm starting to dabble with with connecting JMP and Python.
When I run a small HTTP request (POST) I get the following statement back
getstr = ["shortId" => "4bb3c98fb63579f6f1c615b1adcdc8d5", "userListId" => 30913859];
I'm trying to find the syntax to retrieve  the value associated with "userListID".
Any help would be greatly appreciated.
Sebastien
Thierry_S
Re: Help with retrieving value from argument
Based on the limited information you provided, I believe that the following formula should do the trick:
Word( -1, getstr, ">]" );
Is that what you were looking for?
Best,
TS
Thierry R. Sornasse
Thierry_S
Best,
TS
Thierry R. Sornasse
Sburel
@Thierry_S Thanks a lot for the feedback. I tried your suggestion but it did not seem to work but in the mean time I've found alternative:
getstr = ["shortId" => "e966660eeb303dac6e426c00e90c856e", "userListId" => 30915202];
user_list_id = getstr << get value( "userListId" ); // this retrieve the info from the associative array.
Show( user_list_id );
