david707
Help with PPK on one-sided data which includes zeros
I’m trying to calculate an appropriate PPK for data with the following criteria:
  • Data lies between 0 and +Inifinity
  • A significant portion of the data is exactly 0, and this represents an actual true 0
  • Has an Upper Spec limit only
  • Heavily Skewed
The distribution should be an appropriate distribution for the data.
What’s the best way to get JMP to do this?
0 REPLIES 0
