Help how to if-else graphic script output based on number of items selected in Local Data Filter
Looking for professional advice. I have these 3 variables:  Y( :C ), X( :A, :B ) to be plotted in a Variability Chart.
1. If number of A selected in local data filter equals to 1, I would like the graphic display output to be as below:
Fill Color( "green" );
Transparency( 0.3 );
Rect( 0, 0, 1, 80, 1 );
2. If number of A selected in local data filter equals to 2, I would like the graphic display output to be as below:
Rect( 0, 0, 2, 80, 1 );
I have a JMP Pro 16.1.0.
Re: Help how to if-else graphic script output based on number of items selected in Local Data Filter
You might have to utilize << Make Filter Change Handler.
