Chan
Help getting rows to populate after renaming columns
Hello
I am trying to create a JMP script that will rename column names that are in another language to English text and create a new datatable with the new column names.  In the script below the column names get renamed below the original column names and the rows of data are lost.  Any suggestions? Please help with scripting answers if you have them!
Thanks,
Eve
ms
Super User (Alumni) ms
Re: Help getting rows to populate after renaming columns
Not sure exactly what you're trying to do with the code in the picture and how generic the solution must be. However, if you just want a copy of a file but with translated column names, and a property that stores the original name, a "subset" should work. I this way, not only the rows but also column properties, cell colors etc. are preserved.
A simplified example:
oldnames = dt << get column names(string);
// List of corresponding column names in another laguage. Could be retrieved from a lookup table (or associative array)
newnames = {"namn", "ålder", "kön", "höjd", "vikt"};
// Make a copy of original table
dtt = dt << Subset(All rows, Selected columns only(0));
// Add a custom property with old name and rename columns
For(i = 1, i <= N Items(oldnames), i++,
    Column(dtt, i) << set property("OldName", oldnames[i]);
    Column(dtt, i) << set name(newnames[i]);
I am not sure if I am guessing correctly on what you are attempting to do, but if you are looking to transfer the data from your dd to the ddt data table, you are not showing anything in your code that is doting that.  Here is a lint of code, that if placed after your 21st line would copy the data from the dt data table to the ddt data table.
Column( dtt, colList[i] ) << set values( Column( dt, OldName ) << get values );
