nathan-clark
Graphics script to detect graph title
I would like to set up a custom graphics script so each graph gets a unique line based on information contained in an associative array. In the example below, I want to have a graph on the line differently for each category... for my actual use, I will need the graph to 'recognize' the heading it's under so I can use the correct values for the line creation.
For the example image below, I manually updated the "F" graphics script to be "F". So I am looking to find syntax to "gather the graph info" ... in my head, if I can grab the outline box title, I can manipulate that to get what I need... but I am not sure if that is the only/best option.
dt = Open( "$SAMPLE_DATA\Big Class.jmp" );
dt << Bivariate(
	Y( :height ),
	X( :weight ),
	By( :sex ),
		Dispatch(
			"1",
			ScaleBox,
			{Format( "Fixed Dec", 12, 0 ), Min( 30 ), Max( 180 ), Inc( 20 ),
			Minor Ticks( 1 )}
		Dispatch(
			"Bivar Plot",
			FrameBox,
			{Add Graphics Script(
				2,
				Description( "" ),
				test = Associative Array( {{"F", {0.1, 50}}, {"M", {.8, 0}}} );
				///gather graph info to get "F" or "M" from output
				graphInfo = "M";// need to extract so it's "F" for female graph
				Y Function( test[graphInfo][1] * x + test[graphInfo][2], x );
			), Grid Line Order( 1 ), Reference Line Order( 3 )
11 REPLIES 11
Craige_Hales
Re: Graphics script to detect graph title
If you make the entire graphic script a function, it gets a this parameter that is the frame box. You can climb up to the outline to grab the title. The benefit is knowing you got the outline containing this graph.
Outline title copied into graph by graphic scriptOutline title copied into graph by graphic script
dt = Open( "$sample_data/big class.jmp", invisible );
bv = dt << Bivariate( Y( :weight ), X( :height ), Fit Line );
(bv << report)[framebox( 1 )] << addgraphicsscript(
	// if a function is used, it must be the only statement in the graphic script
	Function( {this},{titlebox=this},
		// the function can use this to find the frame box, climb to an Outline title...
		While( (titlebox << classname) != "OutlineBox", titlebox = titlebox << parent );
		// then other graphics commands
		Text( center justified, {60, 120}, (titlebox << gettitle) );
		Circle( {60, 120}, 30 );
		this<<backgroundcolor(rgbcolor(.9,.9,1.0)); // make the frame box light blue
Craige
nathan-clark
@Mark_Bailey Thanks for that idea! It's good to know that summarize will match the order of how the graphs will be created in the report. That's something I can see uses for in several of my scripts :)
@Craige_Hales That's a really cool idea with the function, I'll have to play with that, too!
