wr
wr
Graph builder scripting - changing graph properties
I am trying to change properties such as color/size/transparency of both markers and lines on overlaid graphs using scripts (tied to user inputs like check boxes and text boxes). Below is code I was playing with to try and figure how to manipulate the script, but not sure that I know what I am doing :-). If you know answers to questions in comment lines of the code or if you know a syntax reference exists for gb functions, please post...Thanks...
//Create table
dt = New Table("grphbldr.jmp", Add Rows(10),
       New Column("X", Numeric, Continuous, Set Values(1::10)),
       New Column("Y1", Numeric, Continuous, Formula(:X^2)),
       New Column("Y2", Numeric, Continuous, Formula(3*:X^2-100)),
gb = Graph Builder(
       //Syntax to clear variables and new ones?
       //what is Position(1)?
       Variables( X( :X ), Y( :Y1 ), Y( :Y2, Position( 1 ) ) ),
       //information/syntax about Elements, Legend?
       //Why doesn't a legend show for Y(2) points on graph?
       Elements(
              Points( X, Y( 1 ), Y( 2 ), Legend( 1 ), Jitter( 1 ) ),
              Line(
                     X,
                     Y( 1 ),
                     Y( 2 ),
                     Legend( 2 ),
                     //Info about Row order?
                     //Draws lines through missing points?
                     Row order( 0 ),
                     Summary Statistic( "Mean" )
       //what is "400"?
              Dispatch( {}, "400", ScaleBox,
                     //change transparency of points.
                     //Legend Model(1) for points. Properties(0) - for Y1,
                     //and Properties(1) for Y2?
                     //How to set marker type and size for points?
                     Legend Model( 1 , Properties( 0, {Transparency( 0.6 )} ) ),
                     Legend Model( 1 , Properties( 0, {Transparency( 0.4 )} ) ),
                     //change transparency and line thickness of lines.
                     //Legend Model(2) for lines. Properties(0) - for Y1,
                     Legend Model( 2 , Properties( 0, {Line Width(2), Transparency( 0.6 )} ) ),
                     Legend Model( 2 , Properties( 1, {Line Width(5), Transparency( 0.4 )} ) )
XanGregg
Re: Graph builder scripting - changing graph properties
Looks like you've figured out most of it. Follow PMRoz's suggestions for the example syntax for getting marker and marker size into the legend properties.
If you two Ys they can either go in two "positions" or both in the same position. Position(1) says to put the 2nd Y in the same position as the first Y.
This may be a bug or at least a deficiency in a heuristic. GB tries to hide "unnecessary" legend items such as when the points and the lines are the same color. Same goes for regression lines and their confidence intervals.
       //what is "400"?
400 is fixed GB id number for the legend.
You can think of the whole Send To Report() part as an addendum to the GB script, making display modifications after the graph model has been built.
pmroz
Rather than trying to understand the syntax of graph builder, I take a different approach:
I create the graph using graph builder and manipulate it until it's exactly how I want it.  Then I click the red triangle and copy the script and put it into my JSL program.
XanGregg
       //what is "400"?
pmroz
Just want to add that I have done some extensive manipulation of GB commands, but only after working out a complex graph and looking at the code.  I wanted to set my own markers and colors, and show lines connecting symbols, but I only wanted the legend to show the symbols, not the lines.  Once you create a complex example graph you can look at the code and figure out how to recreate it dynamically for other situations (i.e. differing number of things to plot).
There's logic to the GB code but the safest thing to do is create it using GB.
