ssavarmand
Graph Labels as Base-Exponent
Couldn't find a format that can show a graph axis labels as powers of 10. The Scientific format or Engineering format show the labels like 1e-2 or 10e-3.
I am looking to write them as base-exponent type.
Is this possible?
Regards,
Saeid
Re: Graph Labels as Base-Exponent
Have you explored the Axis Settings for the setting of the type of axis?
ssavarmand
Of course. This format is for log scales, to make something like this.
I approximated your desired Axis scaling by taking the log of the data, and then applying the Value Labels column property to the data.  I used the Allow Ranges
Then I just plotted the data
It isn't exactly what you want, but it might be useful.  Others in the community may have a better solution
fkaniz
This is not a good solution. Can any tech person from jmp solve the issue?
I am not sure if this result is what you want. Here is weight versus height from Big Class example.
I created a new variable, height 2, by applying the Log10() function to height. The name is arbitrary but cannot be height. Now the axis is exponent. This example has a small range, but you can use the axis settings to round the value displayed to suit your need.
