Thierry_S
Graph Builder in Loop: How do I maintain Y-axis scale across each column?
Hi JMP Community,
I just ran into a little problem with the auto-scalling of axis in the GB platform.
I wish to loop through 100 columns to plot some data on a fixed Y scale (i.e. Min = -1.3, Max = 0.2, Increment = 0.2).
When I save the script from GB, the SendToReport > Dispatch command refers to the Y Axis by its label ("Y-Axis") which will change for each column when I loop through my 100 columns. Thus, how do I replace the expression on line #11 with a relative reference (I tried: Column Name (i) without success).
Here is the snippet of the code I'm trying to Loop through:
Graph Builder(
	Variables(
		X( :Visit Description ),
		Y( column(i) ),
		Overlay( :TRT01 )
	Elements( Line( X, Y, Legend( 9 ), Error Bars( "Standard Error" ) ) ),
		Dispatch(
			"Y AXIS", // Column Name (i)?
			ScaleBox,
			{Min( -1.3 ), Max( 0.3 ), Inc( 0.2 ), Minor Ticks( 1 )}
NOTE: I tried to Lock the axis without success.
Thank you for your help.
Sincerely,
TS
Thierry R. Sornasse
Re: Graph Builder in Loop: How do I maintain Y-axis scale across each column?
Try this:
Graph Builder(
	Variables(
		Y( column(i) ),
		Overlay( :TRT01 )
		Dispatch(
			eval(column(i)<<get name), // Column Name (i)?
			ScaleBox,
Try this:
Graph Builder(
	Variables(
		Y( column(i) ),
		Overlay( :TRT01 )
		Dispatch(
			ScaleBox,
