Martin
Level V
Graph Builder Remove Variable
I am trying to use jsl to remove the x-axis variable and replace it with a different one.  It looks like I should use the GraphBuilderBox <- Remove Variable() tool, but since I change the x-axis variable multiple times, I do not know its name and would like to use the Remove Variable(Role("X"), Position(1)) method, but this does not work.  Any assistance would be appreciated.
Thank you,
Martin
0 REPLIES 0
