datanaut
Graph Builder Plot Height Forced by Data Filter Height
GUI question about graph building.  I use this powerful tool all the time.  I also use local data filters to focus my graphs.
I find when I have many local data filters in a graph builder window, that the y axis of the graph expands to match the cumulative height of all the local data filters.  When I try to shrink the y-axis (for copy/pasting in another application with a preferred aspect ratio/visualization), it won't let me.  So I'm stuck with very tall plots or fewer data filters.
I can see why someone might want to keep all their data filters in view while exploring data but am hoping for the option to adjust aspect ratio when I want to.
Is there a preference setting to change this behavior?  Work-around?
Thierry_S
Re: Graph Builder Plot Height Forced by Data Filter Height
Have you tried switching off the "Fit-to-Window" option in the main Graph Builder menu and then adjusting the shape of your graph frame?
Best,
TS
Thierry R. Sornasse
Thierry_S
Best,
TS
Thierry R. Sornasse
datanaut
That's it! Thanks TS.
