ehchandlerjr
Level V
Graph Builder - Formula button not working
Hello - Feeling a bit silly here. I've never actually gotten the function button in graph builder to work, but now I need it to. I've input a formula into a column, the column fills with no error, and I plot the column (predicted ionization energy) in graph builder against x, click function button at the top, and nothing happens. What am I doing wrong? I put a script in the top left to see exactly what I did.
Thanks!
Edward Hamer Chandler, Jr.
ehchandlerjr
Level V
Re: Graph Builder - Formula button not working
I believe I've figured it out. I think its that I had other columns in my formula, and since graph builder is set up as a y by x setup, any change in the other columns couldn't be accurately represented, so it just doesn't plot it. Would be cool if it had a slider for the other variables not in the x-axis though.
ehchandlerjr
Level V
