RA899
Getting a dot " . " as a result when computing Column Mean and Qunatile.
I'm trying to get the column names from a table, save it, and then extract its properties. When I try to get the column mean or Quantile but the return is just a dot. No number is returned. The columns are returned as a list as shown below. The results are shown below too. Your
Your help is appreciated.
Re: Getting a dot " . " as a result when computing Column Mean and Qunatile.
You need to properly reference the column
q_M=col mean( column(char(colnames[21])));
or
q_M=col mean( eval(colnames[21]));
or
hogi
Level XIII
wow, Eval(colname) works here as well!
Alternatively, you could send the table the message get column references() to get column references which can be directly used in the code.
The only disadvantage: there is no option continuous to selectively pick the continuous ones.
The workaround: get column references() accepts a list of column names (or strings):
Names Default to Here(1);
AllcolNames = dt << get column references();
colNames = dt << get column references(dt << get column names(continuous));
Col Quantile(colNames[2], 0.95);
