Jackie_
Get values in the list from SQL query
Is there way I could insert the column values in the list than jmp table?
I 'm trying to write a JSL code to query data from database and I want to store the values from the SQL table into a variable list (not in the JMP table).
For example, save the WorkCenter sql table values in the list= {};
Any suggestions?
Thanks,
Jackie
Re: Get values in the list from SQL query
The simplest thing to do, would be to extract the column of data into a JMP data table(it can be an invisible table if desired) and then to use
ValueList = :column name << get values;
to move the column of data from the data table to a list, and then simply close the data table.
Jackie_
Hi Jim, That's what I am doing rn, but the problem is it will keep generating multiple tables every time the query is run.
Thanks!
Your JSL should be able to delete all of those data tables very quickly, so they will not create any issues for the user.
1. Perform the query and get table as invisible/private
2. Get values from the table
3. Close the table
(4. Write a function to do all this if you repeat it many times with different queries)
