Generate data using the Arrhenius equation for pharmaceuticals
Greetings!
I am looking to generate data based on the Arrhenius equation for pharmaceuticals under different temperatures. The data is to study how temperature excursion would affect the behavior of the product in last-mile delivery. The problem is, I have no initial data [which I have been searching for quite a while to no avail]. Would it be possible to generate such data with JMP?
Best,
Re: Generate data using the Arrhenius equation for pharmaceuticals
Go to
     Help=>JMP Help
Search on Arrhenius and you will get information on JMP's abilities in this area.
