M0gAl0g
Formula to return value from a row, where row is the Maximum value from a different column
I am looking for a formula that does the following:
1) Evaluates the maximum value of a column, by a Grouping Column
2) Once the largest value is found for each "group", I need to return the value in another column corresponding to that row for each "group".   Is this possible?  This would be so easy in Excel.  =(     Example below.  Thanks a million
GroupingColumn for ReturnColumn to Eval MaxOutput Column with Miracle Formula
12523000
12625000
1273000027
12810000
12925
2251
2262
2273
2284
229529
jerry_cooper
Staff (Retired)
Re: Formula to return value from a row, where row is the Maximum value from a different column
Does this work for you:
If( Col Max( :Column to Eval Max, :Grouping ) == :Column to Eval Max,
 :Column for Return
jerry_cooper
Staff (Retired)
 :Column for Return
M0gAl0g
That does the trick.  Thanks, Jerry--you really made my day.
