XiangLoh
Handling missing data when plotting variability charts with multiple Ys and BY groups
m1m2m3m4m5m6 m7m8DeviceFamily
12-2-1-32-1.50.5D1F1
2-2232-112D2F1
1.522.520.51-1-1.5D3F1
-11-1-1-0.510.5-1D4F1
2-31-21-2.50.5-1D5
F1
-3-0.5-11.5..-11D6F2
2.510.51.5..-0.52D7F2
I am going to use this table as an example. Assume that m1-m8 are some test parameters of some devices. In the actual table, the number of test parameters queried may be different. I want to plot variability charts using JSL for those parameters across Device for different Family.
In JSL, I did
myVC = Variability Chart(
			invisible,
			Y(Eval(parameterlist)),
			X(:Device),
			By(:Family)
I have grouped the parameters m1-m8 as parameterlist. However due to the missing data, the code would result in error when it tries to plot the charts for F2.
Is there a way to handle the missing data? I want JMP to still plot the variability charts for F2 for the parameters that have data. (m1,m2,m3,m4,m7,m8 in this case). After that I want JMP to display the variability charts by family and save it as a html report.
F1 - m1
F1 - m8          (Order in which variability charts are shown in the report)
F2 - m1
F2 - m8
Note that the number of test paramters, number of device and the number of different families may vary depending on the queries.
gzmorgan0
Re: Handling missing data when plotting variability charts with multiple Ys and BY groups
XiangLoh,
You might want to review an earlier post
https://community.jmp.com/t5/Discussions/JSL-Generate-x-y-Plot-that-loops-through-columns-with-diffe...
The recommendations, I made there, I would apply to your data. Here are the steps/ pseudo code:
  • create parameterlist (already done)
  • Run, summarize( fgrp=By(:Family) ); the fgrp is the list of family values
  • nw = New Window("Tests",  vl = VListBox());
for( i=1, i<=nitems(fgrp), i++,
  fam = fgrp[i];
  for(j=1, j<=nitems(parameterlist), j++,
    param = parameterlist[j];
    idx = dt << get rows where(:Family == fam);
//    compute the number of non-missing values for column(param)[idx]
//    if that number is greater than 0 or some minimum you set then
      myVC = dt << Variability Chart( invisible, Y ( AsColumn(param) ) , X(:Device), By(:Family), where(:Family==fam) );
      get rid of the where where textbox and append to VL
); //end j
); //end i
This method gives you a lot of flexibility.  You could save a different HTML for each family, or change the order and plot by variable then family.  Instead of the code for the 2 commented steps, you could use a Try()
Try(  myVC = dt << Variability Chart( invisible, Y ( AsColumn(param) ) , X(:Device), By(:Family), where(:Family==fam) );
//      get rid of the where where textbox and append to VL
,  //else do nothing
   Show( "variable " || param || " for Family == " || fam || "has no valid data." )
It looks like a lot of work, but I have found that most scripters after they have done this once, and realize the amount of options this method offers, they use it often.
Good luck!
gzmorgan0
XiangLoh,
  fam = fgrp[i];
); //end j
); //end i
,  //else do nothing
Good luck!
XiangLoh
Nice! Although I noticed that AsColumn in the variability chart doesnt seem to work for me. Changing it to Column (parameterlist[j]) works
