MuttonChops
For Loop inside a tab box where each loop creates a different tab in the window
I'm attempting to loop through a variable list of tools (ChamberTool or Cham) to create a list.  Then using that list I create a contour of the data by date where each chamber is a separate tab on a tab box window.  I've done each of these things independently but my particular issue is creating a tab for each tool from this variable list.  Maybe my approach is way off but here is my script.
First, here are the two bits of script I have that work.  I hand wave over the scripting of the parts that I already know how to do and to keep this post more brief and not detract from my main problem statement.
ContourG = dt << Contour stuff here;
Graph = new window("Contours", tab box(
		"Tab Name Here", (vlistbox(ContourG)),
But when i try to run a for loop i am completely broken.
Cham = Associative Array(Column(dt_stacked, "Chamber") << Get Values) << Get Keys;Associative Array(Column(dt_stacked, "Chamber")<< Get Values)<<Get Keys;
	For (x=1, x<=nitems(Cham), x++,
		ChamberTool= Cham[x];
		G_Contour = Cham[x];
		ContourG = dt_stacked << Contour Plot(
			X( :XLoc, :YLoc ),	Y( :Thickness ),
			Where( :Chamber == ChamberTool ),	By(:Date),
			Chart Parameter stuff here,	SendToReport( other stuff here)	),
		ChamberTool, (vlistbox(ContourG)),
11 REPLIES 11
jietan25
Re: For Loop inside a tab box where each loop creates a different tab in the window
Thanks for the input. My report will generate about 8-10 charts per feature, chart type will be different by type of feature, there are 3-8 features per layer, and  up to 10 layers per product, products could be varies depends on days of data pull.  Is that possible to store all plots/charts in a list or array for easier access thru FOR LOOP?
Here is a script that generates prebuilt analyses in one window, and a second window dynamically genrates the displays in real time.
dt = Open( "$SAMPLE_DATA/semiconductor capability.jmp" );
// Create the default lists
namesList = {};
objList = {};
// Generate the output names
For( i = 1, i <= 10, i++,
	Insert Into( namesList, "Analysis " || Char( i ) )
//Pre run the reports
	objList[i] = V List Box( Oneway( x( :Site ), y( Column( i + 4 ) ) ) )
// Create the display window for to display the prebuilt reports upon a user's reques
nw = New Window( "Output PreBuilt",
	theHLB = H List Box(
		lB = List Box(
			namesList,
			maxselected( 1 ),
			Try( myObj << delete );
			theHLB << append( myObj = objList[Contains( namesList, (lB << get selected)[1] )] << clone box );
// Create the display window for the displaying of the dynamically created reports
nw2 = New Window( "Output Dynamic Creation",
	theHLB2 = H List Box(
		lB2 = List Box(
			namesList,
			maxselected( 1 ),
			Try( myObj2 << delete );
			theHLB2 << append(
				myObj2 = V List Box(
					Oneway( x( :Site ), y( Column( Contains( namesList, (lB2 << get selected)[1] )+4 ) ) )
