Kaik
Fit data to a logistic function with a known asymptote
My goal is to fit this data to a logistic function (Logistic 3P for example). The y variable represents a proportion, so the maximum possible value is 100%. So I need to specify the asymptote as 100% because the model gives me values up this limit, and this is empirically impossible (attached image).
Thak you for the help.
peng_liu
Re: Fit data to a logistic function with a known asymptote
If I understand correctly, you need to fit Logistic-2P, because the asymptote is known.
In that case, you need to normalize your data, such that Y is between 0 and 1. In your case, I guess that you should divided your Y by 100.
After that, the Logistic-2P will be available:
Scaling your data should not impact the other two parameter estimates, i.e. the remaining two estimates are same. Unless you want to do some kind of prediction of Y given "cp", then your need to scale back after prediction using the fitted model.
It's hard to tell from just the screenshot: are you using Fit Curve, Nonlinear, or FDE platforms? Also, is it possible to share an anonymized set of the data to work with?
peng_liu
Kaik
Thank you so much! I have another doubt related to this kind of analysis.
When I try to compare parameter estimates, I obtain this error:
And when I try to make a custom inverse prediction, the std error in two variables is massive (the others are so good):
Is it possible that these two treatments cannot be modelled? Is there a possible solution? They are the two curves marked with an arrow (yellow and purple).
Thak you for the help to all users!
peng_liu
There is not enough information here so that I can tell what is going on. From the fitted curve, I suspect the Growth Rate estimates of those two are relatively large. From the inverse prediction, seems the models have large uncertainties. I cannot tell where the uncertainties are from based on what I see here.
Kaik
Thank you for you help Peng.
If you want, I can pass to you an anonymous data set to "play" with it, to discover what is happening here :).
Should you be concerned at the lack of parallelism among these curves?
Kaik
Hello Mark,
Not so much, because they are different treatments, and each one reacts different. If you want, I can send you an anonymous dataset to investigate it :).
Thank you so mucho for your help!
