kbatch
Fit Group and Fit Y by X
Hello! I'm attempting to script an analysis where the user inputs a data table, and the script runs a fit Y by X with a user selected column through a column dialog box as Y and all other columns (which can be any mix of continuous and nominal variables) as the X selections. Is there a way to use fit Y by X and Fit Group together to get this all-in-one window and easily allow for the results to be ordered by goodness of fit?
This is a script I wrote that outputs them all in one box, but I want the user to easily find the significant fits by ANOVA. Ideally, I would like to output significant fits to a tabular report window, but that is above my knowledge right now. Any help would be appreciated!
dt = Current Data Table();
dlg = Column Dialog(
	iv = ColList( "Depedent Variable",
		Min Col( 1 ),
		Max Col( 1 ),
		Data Type( "Numeric" )
If( dlg["Button"] != 1,
	Beep();
	Throw();
iv = dlg["iv"];
n_cols = N Cols( dt );
New Window( "Report",
	H List Box(
		For( c = 1, c <= n_cols, c++,
			Fit Y by X(
				Y( Column( iv[1] ) ),
				X( Column( c ) ),
				Fit Line( 1 ),
				Anova( 1 )
Re: Fit Group and Fit Y by X
The script below, runs the Fit Y by X and then output the Summary of Fit table for all of the analyses.  I hope this is what you want.
		Min Col( 1 ),
		Max Col( 1 ),
		Data Type( "Numeric" )//,
		//modeling type(ordinal,nominal)
	Beep();
	Throw();
iv = Char( dlg["iv"][1] );
// Get the names of all of the columns in the data table
colNameList = dt << get column names( string );
// Remove the Dependent Column from the list
Remove From( colNameList, Contains( colNameList, iv ), 1 );
ft = Fit Y by X(
	Y( Column( iv ) ),
	X( Eval( colNameList ) ),
	Fit Line( 1 ),
	Anova( 1 )
(ft << report)[1]["Summary of Fit", Table Box( 1 )] << make combined data table;
Here are a couple of notes:
  1. When you post JSL, please use the JSL icon to open the JSL window and copy the code into that window.  It allows for a cleaner display of the entry.
  2. You need to take the time to read the Scripting Guide, which is available in the JMP Documentation Library, under the Help pull down menu.
  3. The Column Dialog() structure has been depreciated.  You need to move to using a New Window with a Col List Box().
		Min Col( 1 ),
		Max Col( 1 ),
	Beep();
	Throw();
ft = Fit Y by X(
	Y( Column( iv ) ),
	Fit Line( 1 ),
	Anova( 1 )
kbatch
Thank you very much!
