Erez
Find the max slope
Hello everyone,
I have a list of points forming a slanted line, I am interested in knowing the maximum slope created by the curve.
I have a lot of sets of points so I'm interested in knowing how to do it in a formula.
For example, the numbers 1,2,3,4 form a straight line with a fixed slope of 1 so the max is 1. My numbers don't form a straight line so the equation is more complicated.
Attach a sample file.
Thanks.
Craige_Hales
Re: Find the max slope
If the slopes are within each row, maybe this
Capturing the maximum change between columns.Capturing the maximum change between columns.
You might care about absolute value of the change. Abs(point3-point2) ...
You might need a scalable design, handling 100s of columns. That's possible using an array.
Craige
Craige_Hales
Craige
Are you fitting a model and extracting the maximum first derivative, or are you just interested in the most significant difference between points?
Erez
I interested in the most significant difference between points.
That's why Craige_Hales' solution is good for me.
Thanks.
Here is a modification to @Craige_Hales formula that removes the requirement to list each pair of columns
dt = Current Data Table();
Max( Abs( dt[Row(), Index( 1, N Cols( dt ) - 2 )] - dt[Row(), Index( 2, N Cols( dt ) - 1 )] ) );
Here is a different approach using a script. It accommodates any number of data points (data columns) and observations. It assumes that the data table is open and that the last column is dedicated to storing the result.
