nikles
Filter Col Selector: JMP 17 vs JMP19
I'm just curious if there's a setting in JMP19 that controls the column filter feature.  I'm referring to the search box that appears above the column names in the left panel of the main window, or in any of the platforms contains column filter boxes (see image below).
My org recently upgraded from JMP17 Pro to JMP19 Pro (19.1.4).  I'm using Mac OS.  In 17 I could type in space-separated keywords in the column filter box and it show me all the columns containing those key words.  But in 19, it seems like it no longer accepts space-separated keywords, and I have to type in the exact string.
For example, suppose I have several columns of the form:
Volt1_TestXYZ_F0_Row00_Avg
Volt1_TestXYZ_F0_Row01_Avg
Volt1_TestXYZ_F1_Row00_Avg
Volt2_TestXYZ_F0_Row00_Avg
And I wish to filter only columns containing "Volt1" and "Row00".  In 17, I could just type in "Volt1 Row00" to get those columns.  But in 19 it seems like I have to type out "Volt1_TestXYZ_F0_Row00", and even then this would not show the similar columns containing "F1".
Is there a setting that controls this behavior, or is there some wildcard I can use like "Volt1*Row00"?  Thanks.
JMP Pro 19.1.4
MacOS Tahoe 26.6.2
nikles
Re: Filter Col Selector: JMP 17 vs JMP19
Hi Folks.  Never mind...I just figured it out on my own:
Just select the drop down by the little magnifying glass and select "Contains Terms" instead of "Contains Phrase".  Looks like there are some other nice search options added as well.
nikles
