mlo1
Filling Comment into rows by selected row state from scatterplot
I like to avoid the way using the menu Rows -> Row Selection -> Name selection in column
I rather like  to put a comment into rows selected by mouse from a scatterplot via script.
The following does not write the text  to the column and does not give an error in the log.
How is the correct syntax? I am using JMP18
dt = Current Data Table();
//Select data point in graph
// Use column Step do comment the Process steps
// Write the value into all selected rows
For Each Row(
    If( Row State() == 1,  // 1 = selected
        :Step = "Process1"
Re: Filling Comment into rows by selected row state from scatterplot
Hi @mlo1 ,
I opted to avoid looking for state and just grabbing the currently selected rows then using the positions to fill in the column.
dt=current data table();
selected=dt<<get selected rows; //grab the selected rows
column(dt,"Step")[selected]="Process 1";//replace the selected rows with "Process 1"
Thanks,
Ben
Hi @mlo1 ,
Thanks,
Ben
mlo1
Thank you very much.
