File rename
Is there a way of renaming a file within JSL? (i.e. DOS ren command)
Tnx
mattf
Level V
Re: File rename
On Windoze, JMP 8 or greater, here is an example with copyfile and movefile (for rename). LoadDll function makes it easy.
Best,
-Matt
Re: File rename
I won't say it's easy, but it works... I sure hope SAS will add file manipulation functions to JSL in the future to make life easier.
Tnx!
