Fail to save picture in jsl
Hi everybody,
I am trying to script some codes to save all my plots as pictures.
gb << Save Picture( "D:\Document\Variability\" || colList[i] ||".jpg", JPEG );
But I noticed that on those graphs with the header name with "/" in between the name (parameter name like "Win_A/FRP_Thickness"), JMP will prompt an error to tell me that the figures failed to save as pictures in my folder and the whole operation would then be aborted.
Could I seek advice on how should I improve this ?
Thank you...
David_Burnham
Re: Fail to save picture in jsl
First note that JMP doesn't mind whether your path specification uses forward or backward slashes.   Therefore you are specifying a path that looks like this:
which fails because Win_A is being interpreted as a folder and not as part of the name of the file.
Before doing the save you might want to create a friendly file name e.g.
cname = Substitute(colList[i],"\","_");
path = "D:\Document\Variability\"  || cname || ".jpg";
gb << Save Picture(path,JPEG);
-Dave
David_Burnham
-Dave
Couldn't agree more ! Thanks for the suggestion, David
