martin_snogdahl
Extract list from Get List Check-command
Using the Get List Check command I get the following:
LC = col << Get List Check
The Log will show
LC = List Check({"Argon", "Krypton", "Air"});
How do I extract the list from inside the List Check()-statement? I want to end up with a variable containing the list.
LC_list = {"Argon", "Krypton", "Air"}
ian_jmp
Level X
Re: Extract list from Get List Check-command
Take a look in the Scripting Index for 'Head()' and 'Arg()'.
// Make a table
dt =
New Table( "List Check",
Add Rows( 0 ),
New Column( "Check",
Character,
"Nominal",
List Check( {"A", "B", "C"} ),
Set Values( {} )
// Get the values of a List Check property into a list
lc = Column(dt, "Check") << getListCheck;
lcList = Arg(lc, 1);
