powerpuff
Extract column info from jmp tables
Is it possible to extract column info like Column Name, Datatype, Coding and  Design role wothout having to manually right click on each column of a table and copying the data? Thanks for any help.
cwillden
Re: Extract column info from jmp tables
Yes, check out the Scripting Index (Help > Scripting Index) under Data Table > Column Scripting.  The whole section with "Get _______" does the kind of thing you want to do.ScriptingIndex.PNG
 If you want to get everything in one function, you can use "Get Script" though you'll have to process the results a bit to get each component.  Probably easier to write your own function that returns the results of Get Column Properties, Get Name, Get Format,  and Get Modeling Type, etc.
-- Cameron Willden
cwillden
-- Cameron Willden
You can use
col << get property("<prperty>");
to get whatever information you want.
You may be able to get the information you want by using the Column Viewer with it't "Find Columns with Properties".
Finally, one item I hae used is to use
dt << get script
It will detail all of the properties for each of the columns.  However, since it will also contain all of the data for the data table, I typically delete all of the rows in the data table, and then use the << get script.
stan_koprowski
There is a wonderful table properties add-in written by @Justin_Chilton that will do exactly what you need.
Have a look at the add-in and see if will do what you want.
cheers,
--Stan
