bjbreitling
Exclude data when loading data with a script
Hi community,
When I open a table with a database with the following script saved to the datatable it works.  When I save the script to a menu item in an addin it just pulls the data and doesn't exclude.  Whats up?
Open Database(
  "DSN=PI SQL Connection Lab;Description=PI SQL Connection Lab;UID=;Trusted_Connection=Yes;APP=JMP;WSID=SFX-5GCN2M1;DATABASE=LabData",
  "SELECT * FROM dbo.NSI_Discovered_Factors_Lab_Data",
  "NSI_Discovered_Factors_Lab_Data",
"NSI Database"
dt=CurrentDataTable();
dt<<Select Where(Exclude=="Exclude")<<hide<<Exclude;
Jeff_Perkinson
Re: Exclude data when loading data with a script
Thanks for the clue about it working when run from a script editor but not as an add-in.
That usually indicates a scoping problem for variable references in your JSL. By default, add-ins run with the "Names Default to Here(1)" option, so that un-scoped references go to the "Here" namespace.
Your Select Where() has an un-scoped variable in it in the form of Exclude.
If you include a : before it to scope it to a data table column it works in both cases (script editor and add-in).
dt<<Select Where(:Exclude=="Exclude")<<hide<<Exclude;
-Jeff
-Jeff
9 REPLIES 9
Byron_JMP
Its possible that the Open isn't complete when the Select is executed?
I haven't seen this exact problem, but something like it when I'm working with tables that have lots of rows.
Two suggestions:
First, assign the data table to a variable when its opened. This way dt=current data table(); doesn't accidentally end up pointing at the current table, while the database table is opening.
     dt=open database("DNS....
     Leave out the dt=current data table();
Second, force dt to be evaluated before selecting rows. It can't be evaluated before it finishes opening
     dt<<Run Formulas; //include this first
bjbreitling
Hi Byron,
That didn't fix it.  I also made a separate addin that should work given what you said is true which I execute after the loading of the dataset which is just the following.
This oddly doesn't work either.
pmroz
Try using wait(0) instead of run formulas.  I agree with Byron - remove the dt = current data table and set dt = to the results of open database.  Like this:
dt = Open Database(
  "NSI Database");
wait(0);
dt << Select Where(Exclude=="Exclude") << hide << Exclude;
bjbreitling
Same issue PMroz.  Oddly it still doesn't work.
pmroz
Here's a thought.  Since you're pulling the data with SQL, why don't you exclude the rows in SQL?  Also I think you have an extra parameter to Open Database (NSI Database).
dt = Open Database(
  "SELECT * FROM dbo.NSI_Discovered_Factors_Lab_Data WHERE exclude != 'Exclude'",
  "NSI Database");
bjbreitling
That is an option PMroz, but I would prefer pulling the all the data and leave folks the option to un-exclude.
Byron_JMP
There may be a couple of other little things to check, and I apologize in advance for being so basic.
The imported data table has a column named "Exclude"
-does the actual column name have any leading spaces?
-does the actual column name match? e.g. title case and spelling.
The values to filter on in the column named "Exclude"
-do the values in the column have any leading or trailing spaces?
-is the spelling and title case exact for the level "Exclude"?
The script in the data table works, did it come from the Data Filter?
bjbreitling
Hi Byron,
When I copy and paste the query into a script which is exactly the following:
It works.  But when I save the script to a jsl addin, it oddly doesn't.  The column name and case and spaces match.  So does it for the rows.  Its very odd that it works in non-addin jsl but not in addin.  I didn't generate this jsl form the data filter.
Jeff_Perkinson
-Jeff
-Jeff
