TheWho80
Error on "Update Properties ( 1 )" using JMP 15 - script is coded in JMP16
HI,
Im new to JMP and do have a script was coded in JMP 16 but having error on JMP15 on this line during recode.
is this expected? can this be comment out when running on JMP15?
Update Properties( 1 ),
Thanks alot.
David_Burnham
Re: Error on "Update Properties ( 1 )" using JMP 15 - script is coded in JMP16
// sample data
dt = Open( "$SAMPLE_DATA/Consumer Preferences.jmp" );
col = New Column( :Gender );
// get JMP version as a number
jmpVersionNumber = num(words(JMPVersion(),".")[1]);
// don't use  'update properties' before v16
if (jmpVersionNumber>=16,
	dt << Recode Column(
		:Gender,
		{if(
			_rcNow == 1, 0,
			1,
		Target Column( col )
, // else
		:Gender,
		{if(
			_rcNow == 1, 0,
			1,
-Dave
David_Burnham
// sample data
		:Gender,
		{if(
			_rcNow == 1, 0,
			1,
, // else
		:Gender,
		{if(
			_rcNow == 1, 0,
			1,
-Dave
TheWho80
Thanks Dave, looks like "Update Properties" is not a requirement in older JMP version
